Matt_martians
So the story behind this engine(1995 spx 657x) is that was I was doing electrical diagnostics and opened the stator cover to make sure everything is in tact. Found tons of oil. Tore down engine to replace crank seals, found the cage on the front bearing is gone and there's remnants of the cage melted into the front seal. When I lifted the crank up a little bit the balls fell out and so did the outer race. The inner race on the outer bearing slid off when I grabbed it and the second one was also loose but there was a rough section that I had to air hammer it over. I did not run my air hammer very hard at all, I could have probably pushed that out by tapping it with a small mallet. That rough area feels like what a spun bearing on a 4 stroke feels like.
My question is should I replace my crank? Or should I sand down that rough area, make some measurements, and call it a day? Does anyone know what the min ID of these cranks are, as it does not say it in the service manual. If I can replace these bearings does anyone have any tips/videos on replacing these bearings? I'd assume you press it, but do you need to make special fittings for the press and is there anything to look out for? Thanks for the help in advance
