i just bought a 96 challenger which i think i got a good deal on $1200 with trailer. the engine needs to be rebuilt but i had another 787 in another ski that i swapped over. that engine is a freshly rebuilt one with 10 hrs on it and was in perfect running order when i removed it. i got it installed and running on the hose and put a new battery in the boat. now i only changed the engine, carbs and all other parts were not changed. we took it out and it ran real rough got it to plane once and when we slowed down it ran like crap. it will idle but if you give it gas it will get to 2 or 3k rpms at most and shut off. restarts and will idle fine. tried new plugs, thought it had bad gas from sitting for 2 months(had full tank when i got it) tried a little seafoam. well eventually it just died. battery was dead, i dont know if it was from the cranking or if if was just not charging its self and ran off just battery only and had a weak spark and that made it run bad. grey fuel lines had been replaced before i bought it. any directions on where to start will be greatly appreciated
