Ok I have a 2005 GTX Supercharged. I have not ran it in a couple of years. Last time I ran it, it wasn't getting full power. So I thought i would bring this ski back to life. I installed a new battery, new plugs, new ignition coils, and had the injectors cleaned and tested. Drained out old fuel and put new fuel in it. I got it started but was back firing. I found out it was only firing only 2 cylinders. injector one (the 1st one on the fuel rail closest to the fuel line) Is throwing out a large amount of fuel into the cylinder. At first i thought I had a bad injector. but i swapped it out with injector 2 and it works fine there. When you first put the key in the fuel pump primes the lines when that happens injector 1 is throwing a lots of fuel while injectors 2 and 3 work fine. When trying to start, injector 1 is still throwing out lots fuel. So i see what the problem is but don't know whats causing it to happen. Any ideas what would be causing this and what i can check on next?
