I have purchased a GSX ltd,1998. It has the 951 carburetor equipped motor. Seems to go ok although the bendix drive behind the flywheel just dropped a tooth. Guess I have to pull the front off to effect repair. Fortunately as a mechanic for 50 years, just another job. Not much room though. The starter motor splines/teeth are quite worn so predict this contributed to the broken tooth on bendix. However I digress. My main question is.
The jet unit fitted to this ski has no reverse but does have the trim capability. However I’m a little confused as driveshaft has a carrier type bearing and straight hose with two hose clips. It does not have the carbon seal and bellows type rubbers. Is this standard for GSX 1998 or has the pump been swapped for perhaps an earlier model. Working ok as is and no signs of modification but interested in my ski history.
Thanks folks. Nilo.
Thanks folks. Nilo.
