I have a 94 SPX that had a jet pump go belly up. I bought a complete assembly from a 95 spx. I removed the variable trim and looked into the pump to look at the impeller. The part number is 271000445. My old impeller is 271000182. What is the pitch difference for the impeller?
Also, since my last one died, I want to pressure test the pump. I can do the test, but what have you guys used to attach the pressure pot to the pump? It's only 5psi, but I want to be absolute in my readings.
