Greetings all.
I wanted to share a picture of a tool I made to remove junk from my impeller. (Ruler is for reference)
Using this simple tool and a flashlight I have removed bits of wood, rocks, fishing line and other miscellaneous trash including a Gatorade cap that got wedged between the impeller and the wear ring, without so much as turning a bolt
I can go in through the pump exit nozzle or through the intake grate. It is made from aluminum and fits nicely into the storage compartment. It is simple and effective in most cases. For $5 plus postage I'll send you one
Question: I am thinking about replacing the stock impeller on a 2006 RXP that has a few dings on it with a quality aftermarket unit. Can anyone tell me what the stock specifications are (pitch etc) and recommend a replacement.
Thanks in advance for your help
