I just bought a 2004 Seadoo Sportster 150 2 weeks ago, and it needs a new wear ring BAD! It's literally in a couple of pieces. Well I bought the dealer service manual, and began by taking the pump off of the boat. In the dealer service manual it goes through all of these steps in order to get the impeller out of the pump, such as removing bearings and rings and etc,. On other posts I've read that all I need is the impeller removal tool, and the appropriate hex wrench on the other end, pull out the impeller, pop in new wear ring, and replace impeller. Do I have to go through all those steps in the service manual, basically gutting the impeller, or can I just pull it out as a whole. THANK YOU VERY MUCH! I've learned alot from these forums!
