First of all, you need to tell us what ski you have, preferably in your profile so it shows up everytime you post.
Make sure your fuel selector is not turned off.
As for the carb, make sure you recheck that all fuel lines are routed properly and that your pulse line is attached. I will assume you assembled the carb correctly, checked that your low and high speed screws were set according to specs, and made sure your internal rubber parts/diaphrams were in good shape and/or rebuilt with new parts. The filters should have been cleaned/replaced inside the carbs as well.
Also, check your fuel/water separator bowl for a good seal. There is an O-ring on it that needs checked. If you are sucking air in here you will have fuel delivery issues.
That should get you started, but you may have to tear apart the whole fuel system and clean out to solve your problem. This would include replace all the fuel lines, especially if you have the stock gray fuel lines on the older skis.
