So I had the boat out Saturday, and we were having a blast, but then things started acting up.
1)The left side motor takes forever to start, I have to hold the button down for a good 5 seconds until it finally turns over
2)When I accelerate when the left side motor hit's about 2500rpm it dies unless you immediately drop it's throttle lower, and you can slowly rev it up and down and it'll eventually quit doing it
3)often times while I'm cruising if I turn sharply the left side will shoot up to 7000rpm
4a)I don't know if this is just normal or not, but it takes a while to get up to full speed
4b)Also, if I turn to sharp I loose all power and again have to wait for it to regain all it's speed. (again, i don't know if this is normal or not)
What kind of speeds should I be getting while I'm cruising? While I was out there with 2 buddies and we were cruising at about 40 and then later on in the day it started getting sluggish on take off, and we were barely hitting 35.
I'm assuming a carb rebuild would fix some if not all of these?
Thanks for any help!
