Ignition problem with a 96 gsx 787
jerrygena
Hey guys, this is my first jetski and i got it used, was told it only needed a coil but did a comp test and had no psi's on one side and maybe 10psi on the other, so i've put a new topend. When I try to start, no power to the coil via the white wire from the cdi. All fuse's are good, all grounds are good so I pulled the mag cover and the trigger coil measure proper ohms and the mount wasn't broke or bent. So I was wondering what voltage i should see from the trigger to the cdi? I would think it should be less than 5v being a hall effect but I checked less than .2v while cranking, I'm thinking this is to low? And if so is the stator not putting out enough juice?. I'm sure it should have 12v going to the coil via the white wire which comes from the cdi, signaled to do so by the cdi via the trigger wire, any help would be great, thank jerry
Oh, i dont get any beeps when i put the key on???
