Darius
Hello boys and girls!
Got an issue and i do hope that you will be able to help me.
When you start i from cold its all fine, ride as a dream. Give it a blast all fine, then switch the engine off and take the key of.
Now is the problem, sometimes the ignition come back on with double beep without the key ( like you hold the button to start ) and go off again.
Sometimes the ignition dosent go off even the key is removed from the post, and then it wont start, wont even turn over.
When you take the relay off the fuse box and put it back in after 20min or so it will start up again, and as long as you wont switch it off you can ride it all day.
Any one had something similar with seadoo trixx?
I personally think it could be sticky relay.
Just a question before i take it somewhere to get it looked at
