I think it's a breather
1hsv1976
On the d/s front on the rxp x there is a breather I think that's what it is where should that be connected and what does it do
You talking about the oil breather? if it's like mine...i just ran it into my front air (when I had one) intake. helps coat the sc wheel...especially in salt environments.
It comes out on the right hand front of the ski inside the hull there is a black hose it was sitting near the battery I had the air box taken out and I found this hose just sitting there I'm assuming it connects to the battery or the fuel tank cause when I looked at the original air box there isn't anywhere to connect I hope this helps
Pardon, what year ski again? Got a pic of the part?
a hunch...check the upper starbord side of the battery...in front of the hot cable connection...facing the bottm of the hull...is there a nipple there...for a small breather hose?
2009 it's on the right side as when your sitting. On the ski it's about a 1/4 inch hose I think it might go to the battery
