I just wanna ride!!!!
RONDOG73
I just bought my first sea doo, a 95 xp, and rode it for about 30 minutes before it started bogging down. The engine runs great but it just wont go. I used super unleaded and was told that was not good for the oil mixture. So I drained and replaced the gas with regular unleaded and it didnt help. Did I screw it up?
not much to go on
what ur rpms at, at wot? Hows the response? does it take -off good, or just reving and no go?
sounds as though, you need to pull the carbs, go thru them, replacethe grey fuel lines and remove/clean the raves.
So When I went to check the intake filter for debris (I wanted to start basic) I found a large rock stuck where the empellar (sp) is at making the trim stay at full up position. A buddy of mine said that could make it run slow because of the angle of propulsion coming out of the back. I have to charge the battery then take it to the lake and try it.
