96spxpos
oh ok...I thought people usually use them for seized up head bolts or intake manifold bolts, just like the lurch says in this video, lol: http://www.youtube.com/watch?v=99eg03UN1VQ
yeah I thought I read that somewhere here - why don't they anyway? If it's being rebuilt anyway, why does it matter?
oooops, I tried an impact driver, here's the result:
Then, for the other bolt, I tried a huge breaker bar but the socket actually rounded the hex head and now I cant get it to bite. So now I'm stuck, any suggestions would be very welcome!
Get a set of 6 point sockets and this won't happen very often if ever. Automatic transmission fluid and acetone mixed 50% is the best penetrating fluid I know of.
dremel with a grinder attachment
SBT will have no problem exchanging their own engine, i am running probably a 2 -3 year old sbt engine right now, first off, an rfi is no high performance ski, it was built for fuel economy, what you need to do is determine what is wrong, and how it happened, also, everyone here when they rebuild a carbed ski, they change fuel lines, o/haul carbs, oil pumps, and filters and oil inj hoses, and rfi is no exception, replace with a reman, replace injectors, and fuel pump, put some oil lines and if you want a new oil pump, and will be a good ski for a while ...me, and a friend of mine has done what i just stated, with SBT, and have no issues really, I'm not sure of other builders, i have seen SBT's operation first hand, been there a few times and have been through the whole rebuild line, thats why, personally i deal with them ... and its only a 40 min drive, so i pay no shipping ...
if...you don't find out what went wrong, it will happen again ....
I used a 4" angle grinder with a metal cutoff disk to get the head off of the bolt that wouldn't come out of one of my motors.
Yep, pull it out. It will make getting the broken one out easier anyway. Worst case scenario you can clean everything real well while it's out.
Nope, order an Impeller removal tool and remove the PTO before you pull the engine. It's not fun wrestling it on the ground trying to get the PTO free, no need to ask me how I know. I'd also just pull the RV cover off and remove the rotary valve and get a visual on the crank, if you see rust just pull the PTO leave the rest together and order a reman engine. Let the shop you send it to deal with all the broken crap. Actually you should have pulled the RV cover first if that engine was locked and let who ever builds it deal with the broke head bolts. Could have even pulled the raves so you could have looked into the cylinders.
