Hi all,
I'm bought my first used 96 gsx recently, and today while teaching someone how to board, after flipping the thing 3 times my seadoo hydrolocked in salt water. I took out the spark plugs, hit the starter, blew all water out, and eventually got the seadoo running again and rode it with wide open throttle for about 30minutes. After I brought it home and flushed it, rinsed the engine, washed the hull, sprayed wd40 on the impeller and the rest of the rear end.
I was going to fog the cylinders after flushing but I cant find my spark plug socket now...should I do this asap? Does it matter since I already ran the engine?
Can someone tell me if I need to do anything else, such as fog the cylinders or any carburetor maintenance to avoid any damage from salt water hydrolock.
Thank you.
Thank you.
