gustofusion
Hull repair, Gel Coat and possible fiberglass 1997 Seadoo GTX
Several questions.
1: How can the plastic fender/bumper be removed to get a better look as to possible damage under it. See Photo 1
2: The damage looks as if the fiberglass itself is partally cracked. If its repaired should the fiberglass be patched/repaired on the inside and outside of the hull or only on the outside or only on the inside?
3: Gel Coat, If the crack does not exist on the inside of the hull but only on the outside can a repair be made with gel coat only?
4: Where can gel coat for the 1779 Seqadoo GTX be purchased for this model Green. I would like to get the exact color match for this repair if anyone knows of a dealer/distributer of a gel coat that is this color green as exists on the hull.
Several questions.
