How to Remove 4-Tec Flywheel?
Rsoxs19
My supercharger blew up and it took out a lot of teeth on the flywheel. I have a 2006 RXt 215 but with the xcharger upgrade. Was wondering how to remove just the flywheel? Are there any special tools involved or do you just take out the flywheel bolts?
You have to remove the engine and tear down the entire engine to remove debris and inspect for damage, more than likely it takes out the oil pumps and they are built into the case. However If you remove the driveshaft , supercharger , valve cover , loosen the chain tensioner you can remove the flywheel cover, any debris in there also will damage the stator. If you are going for it I recommend you get a manual, it tells you what you need to put it back together.
