So it's been a long winter, and I want to give a little love to my boat. What are the good yearly maintenance things to do?
1. Oil change. I would like to supply the oil and filters to the mechanic to make sure top notch stuff is used. What is a good oil and filter to get for a SC 4-Tec?
2. Spark Plugs. I'm not sure when they were last changed, so it would probably be a good idea to change them out. What is a good plug to buy, and what gap should I set it to?
3. Impeller wear ring. During a hole shot, the right engine revs up a bit more quickly then the left, so I know at least that wear ring is a little worn. Should I go ahead and replace both if I am replacing one?
4. New Battery. Check!
5. Anything else?
The engines have about 120 hours on them I believe (will check while at the shop)...but the boat runs like it is brand new...so I'd like to reward it with some nice maintenance to keep it that way!
I actually took the boat out once in late February, and it ran like a top...as if I had only been sitting for a few days (it had actually been sitting for a few months).
Finally, what are good cleaning products to use on the seats, and on the hull and interior of the boat for a good cleaning and to try and get that brand-new-white color back?
Thanks to all in advance for the help!
5. Anything else?
