steve on the water
I am having trouble getting on the water this year. There is power to both starters and they will spin when trying to start the engines. There is no spark to either engine. I am hesitant to propose the same component failed on each engine. Looking at the wiring diagram, the only components I see in common for both engines are the battery and CPU Master within the MPEM. It is odd to me though since the starter commands also come through this component. I am starting to check all grounds and run through the MPEM Procedure in Section 7-06 of the manual but am concerned that I will not find an answer. The suggestion on the manual is replace questionable components to determine if they are bad. I do not expect that anyone has an extra MPEM laying around to swap it out to determine if that is the issue. I would be worried that if the MPEM was bad, and nothing was done to find the fault that killed it, you would risk killing a known good MPEM. How do I go about proving the MPEM is good or bad? The advanced diagnostic test causes the engine to try to start. The manual would make me think the MPEM is good. Is this a ground issue? Could a bad ground cause a drop in voltage to prevent a spark but still provide enough power to spin the starter? Maybe a bad battery? My wife is going to pull the plug and sink the boat. Help! Thanks
