A avasdaddy New Member Aug 5, 2010 #1 how tight should i tighten the bolt that holds impeller and wear ring housing?
Dr Honda Well-Known Member Aug 6, 2010 #3 If you are talking about the bolts that hold the pump to the boat... I just make them snug. I'm sure there is an actual spec... but I just tighten them. BUT... Pump hull nuts: 26 Lb/ft Pump housing: 18 Lb/ft Nozzle: 15 Lb/ft
