k_24 Active Member Apr 22, 2018 #1 I have a 2002 seadoo xp 957 I rebuilt my carbs last april How often do i need to rebuild them ? Or change other maintenance parts seasonaly ?
mikidymac Moderator Staff member Moderator Apr 22, 2018 #2 They should be fine. Every other year or so should be good. I’d do the pump oil every year because it’s cheap and easy.
k_24 Active Member Apr 23, 2018 #3 mikidymac said: They should be fine. Every other year or so should be good. I’d do the pump oil every year because it’s cheap and easy. Click to expand... Ok thanks for the info
C CReynoldsMIZ Well-Known Member Apr 23, 2018 #4 I wouldn’t rebuild them unless the machine is running poorly. If you keep it using fresh gas and stabilizer and take care of it, run it til you notice a problem then do it immediately.
