How much oil with fuel for break in???
yelah
What is the best mixing ratio for engine break in. Also how much fuel should i use during break in? Full tank (40gal) or just 12 like the manual says?
Depends on of your still using the oil injection system.
If you are, 50:1 along with the oil injection system for the first ten gallons of gas.
If you have the pump blocked off, 32:1 for the first ten gallons of gas.
