How do you properly start a 98 speedster???
kingofpita
Ive never really known how to properly start my speedster and its getting very annoying. Certain steps I should take?
Turn on the fuel, turn on the blower or vent the engine compartment, be sure the shifter is in neutral, pull the choke if it is cold, listen for 2 beeps, push the start buttons.
What problem exactly are you experiencing?
Karl
Karl
Well, it usually turns over for a long time while I try to give it gas but i end up flooding the engine. I changed the spark plugs and did compression tests and it was running good for a while. And now its going back to turning over but not running. Sometimes the engines also turn on for a few seconds and then turn off again.
It could be several things. First is the compression close to the ideal 150 psi per cylinder? Have the Carbs, been cleaned lately? Are the Low Speed screws adjust to 1 1/4 turns out and High Speed screws set to "0"? Are both carbs in sync? Is the gas fresh? Have you checked the plugs and gaped them properly? It might be the spark plugs are fouled too, it is a 2 stroke. Also if the spark plugs are fouled is the oil injector adjusted properly so it isn't pumping too much oil? Check these things out I suggested and let me know if it helps out.
Karl
oh wow, thats a huge amount of info and also a lot of stuff I dont know much about. I'll have to contact my mechanic about that but ill make a list of all those things you mentioned and have him double check.
Thanks Karl
If you want to tackle any of the items in my post, we could talk ya through it if your mechanically inclined. These are just the basics to cover to help you resolve your problem. Let us know if we can help out any more. We're here for you. :)
Karl
