uraceulose
I finally got this thing running half way decent to where I felt comfortable putting it out on the water.
It runs very strong from half throttle to WOT. Especially the driver side engine in the upper RPM. The passenger side runs good but doesn’t feel as strong in the upper RPM. Oddly the passenger side runs really smooth from idle to about half throttle and the driver side engine will boy rev up unless I feather the throttle up to about 4000 rpm. I basically work the driver side throttle by itself until it’s got some rpm then hit the throttle on the passenger side engine and it jumps right up on plane then runs great as long as I keep the RPM’s somewhat up. I’m going to keep tinkering with the low speed screws on the driver side engine and see if I can get it to run smoother as I roll onto the throttle. It’s off too that the driver side engine fires right up then idles great then has issues from off idle to about 3500-4000 rpm then runs like a raped ape but the passenger side cranks for a few seconds before firing then idle great and revs right up but doesn’t seem to have the same top end as the driver side.
Anyway here are some photos of plugs. This is after 60-90 seconds of WOT then pulling the lanyard while at WOT and immediately pulling them for inspection. I’m running 40:1 pre mix to be safe as I’m not sure my new used oil pumps are working properly.
The lighter looking one is identical to the other and seemed a little too white for me but that’s why I’m asking your guys’ opinions.
1996 speedster running pre mix for who knows how long and got 47 mph on the speedo with a 180 lb passenger plus me at about 185 on fairly smooth but not glass like water.
Thanks for any suggestions or comments,
Donnie
Donnie
