bigJake
I snapped the head off my oil bleeder screw on my '96 GSX last night. This morning I see air in the lines to the manifold. Not sure if the broken screw is not sealing the hole and air is leaking in or if this is just air I didn't get bled out last night when I changed the oil and it worked it's way into the lines overnight. No oill came out the bleeder when I opend it last night, before i snapped it off. But I held the injector wide open at idle last night and cleared the air out of the lines out so the air in the lines now appeared overnight. Is there an epoxy or something that I can put over the broken screw, maybe the stuff you can use to seal gas tank holes?
