How can I pull the check engine codes from 2005 RXT ?
The ski does not start, also displays check engine message., no spark., changed spark plugs, 3 spark plug modules., tried an ECM from the other RXT., still no luck .., is there any way to pull the codes without using BUDS ? Could it be a knock sensor or tps sensor that can cause no spark ?
Thanks
Vlad
Thanks
Vlad
