I have a 1996 Seadoo GSX that was having an intermittent issue with two short beeps and then four beeps when key is connected. I know this can be caused by the Holder Relay. When I get the beeping sequence, the gauges power up and the down after the four beeps. Recently it has become a constant issue.
The question is, is there a way to test the Holder relay? I had someone say to ground the relay and apply power to the red/blue wire and see if it works. As there are two of these red/blue wires, I tried the one that does not connect to the MPEM. I did not get any clicks from the relay. I do not want to blindly try other wires with out guidance.
Can anyone shed some light on a proper way to test this relay to see if it’s any good?
Thank you in advance.
