L Lori1 New Member Jun 8, 2009 #1 This may be a stupid question but I will ask anyways. I have 1997 Challenger and one of the engines starts and will not go below 2500 rpms. Is it within the cable adjustments or carb? Thanks, Lori
L Lori1 New Member Jun 9, 2009 #3 It is running 2500 rpm on one engine and the other is running @ 1500 in the water. Thanks for you reply Lori
kcr357 Active Member Jun 9, 2009 #4 3k on land, 1.5 on water. The idle is adjusted by a stopper on one of the carbs on each motor.
T timmyboy76 New Member Jun 9, 2009 #5 Lori1 said: It is running 2500 rpm on one engine and the other is running @ 1500 in the water. Thanks for you reply Lori Click to expand... M9ight need to go thru carbs, and see whats happening. If you just bought it, the nmaybe they messed with settings to accommodate a clogged carb...
