high/low speed adjuste location on 01 xp?
jimboslice
does anyone know where the low/high speed adjusters on the carbs are on the 951 motor. im having a lil acceleration problems and wanted to try adjusting those before taking carbs off and cleaning them.
They are on the same place as any other seadoo. Low... bottom, on the cable side... High... top, on the opposite side.
If you have acceleration issues... the needles won't change that. Those carbs need cleaned. If you take the lazy method to try to fix the problem... you could melt the engine. Fuel problems on a 2-stroke engine are a VERY serious issue. That's what cools the piston crowns, and transports oil into the engine.
