Jaxtoce1
I have a 96 GTX 787 and from idle (standstill) if you mash the the throttle it hesitates and bogs down for a good 2-3 seconds and then takes off... not really sure why it's doing this. Personally I don't mind having to butterfly the throttle a bit to get it going but for newer drivers like my brother he will end up stalling it a lot or getting so aggravated with it he doesn't want to ride. Other than the hesitation off the line the ski runs great. Once it's gets going throttle response is smooth and direct and top speed is about 45. Yes I know it should do 55 but the hull is pretty beat and the impeller could use a replacement so I'm ok with that speed.
Does anyone know how to fix this hesitation off the line? I'm assuming it's a tuning thing with the carbs? Also was told it could be an accelerator pump? Lmk what you guys think
