help with vts install
Hardworkinman
I am having a heck of a time trying to get the connector off behind the information screen underneath the handlebars. The instructions say to insert a small flat screwdriver in the pry holes. However, doing that does not detach the connector.
Has anyone else had an issue with this and could you please give me some advice on how to take it off please?
Thanks in advance!
It will not let me upload pictures dang it
There is a red tab that needs to be pulled downward when you are prying the two apart. You should be able to see it if your slightly pry the two pieces apart.
Pulling the red tab down will dis engage the plug.
