randy_oneal1
I just bought a 97 Challenger 1800 and I am missing a little part on the drivers side of the boat (not out the back by the jets, but out the side), it is just above the water line, has kind of a wire meshing inside the tip of it, and has threads on it but I guess I am missing the the part that screws on the threads. I can't find it in any of the parts diagrams and It doesnt list it in the owners manual. I went to the seadoo shop and ordered a part but they said I needed a scupper valve and from everything I have seen on here the only scupper valve referenced seems to be the one that was recalled going to the drain under the drivers seat (which I need anyways) and out by the jets. However, the parts guy did tell me not to use it until I get this part because this little port was an exhaust drain and I had to have the scupper valve or water could go back up the exhaust, is this true? The guy I bought the boat from said (and gave me reciepts for the work) he had just had the fuel tank pumped; carb cleaned and new carb jets because he some how sucked water into the carb. Would this missing part be the cause of that?
Thanks for your help!
