Im looking for help diagnosing a charging problem with my 2006 3d 951 di. I only have 1 to 2 volts dc coming from my rectifier. 1 volt at idle (maybe almost 2 when I rev it). I did see 12 volts for a brief second. I got another used rectifier today and got the same 1 to 2 volts. Actually last week I wasnt getting any dc voltage from the original rectifier. When the new (used) one showed up today I was getting 1 to 2 volts. I went back to the original rectifier and was getting 1 to 2 volts with that one also now. I tested the 3 pins on the harness from the stator and was getting 50 to 60 volts ac between all three wire combinations when I rev the motor. The service manual says it should be between 45 and 80 volts ac. I tested resistance between all 3 of these wire combinations and it was .1 to .2 ohms. The service manual says it should be between .1 and 1 ohm. When I tested each of these wires to ground, I was getting between 11 and 14 mega ohms. The manual says that all 3 of these wires from the stator should read open to ground. Since Im getting good voltage from the stator and 14 mega ohms is barely any resistance Im wondering if the stator is really bad. It seems weird that I would get the exact same voltage from 2 (bad?) rectifiers. Thanks for any help guys
