HELP!!! Sea doo gti starting problem
Coltongus
I have a 2004 sea doo gti 2 stroke and I just replaced the battery and starter and was riding around with no issues and then I stopped to just chill out at the beach and I went to turn it back on and it crank up then die I thought it could have been the plugs so I replaced them and now it beeps and it just clicks when I try to turn it on I don’t know what to do
1. Check the battery voltage at rest and when trying to crank. Could be a bad battery.
2. Next pull the spark plugs and make sure you can turn the engine over by hand to make sure nothing is locked up.
3. Try jumping the starter solenoid big copper posts to send power directly to the starter, could be a bad starter relay.
