Itbrokeagain
I picked up a cheap 1990 Sea Doo SP 580 last week, and after a bit of tuning and bew plugs she was running pretty good. Even pulled a tube! I got home that night and pulled the 'sending unit' (hoses) off the top of the tank to get a better look at how much gas we used to get an idea of what to expect from the machine. One of the pick up hoses cracked off. No biggie. I cut it a little shorter and stuck it back on. Cracked it over, it fored right up and then died, as expected, when it hit the air bubble in the line.
Thing is... that was a week ago. And it still hasnt ran off its own fuel since.
I found out i put the pick up tube on the wrong spot and got straightend out but still nothing. The pump shas fuel to it... and some comes out but im not sure if its enough honestly. Anyway, ive ordered a new fuel water seperator/filter aftaid it was letting air in. And it was NASTY. Also a pump rebuild kit. But heres where i need help.
*important part below*
The carb on this craft doesnt seem to exsist. Its a Mikuni with the number 995 and 956 stamped into it, but i cant anything online for a numer, rebuild kit, anything. No internal pump. Ill put a link below to a picture of an identical carb, filter, and pump, minus the black air box on top of the carb. I should mention this is a yellow 587 type motor that is suspiciously clean. What i need from you guys is any help identifying this thing! Thank you!!
