I have 2006 seadoo gxt sc 185 hp 200hr I do regular maintenance. my speed is down from 65 down to 50. rpm is good
I had the sc washers changed at 100 hr not sure what type the put in. sc is tight.
so I pulled the pump to look so now I need parts I need a ware ring new impeller the grease is clean. I would like to get the speed up to 70.
sbt has a reman impeller for 60.00 reman pump for 400.
I think I would like to upgrade the impeller not sure what one I need or is the best?
not sure If i need to redo the sc washers?
I also read some stuff about the drive shaft seal?
2 degree spacer?
I'm open for suggestions to get me up to 70 mph
thanks
phil
2 degree spacer?
thanks
phil
