DooGuy
Hello All, new to the forum, needing some help with my boat. Appreciate any help. Sorry for the long details to follow, will try to be short. '07 Challenger 230 SC, in the fall while cruising engine suddenly stopped. tried to get to go on water but nothing. limped back to shore and loaded up on trailer. at home tried again to crank and no go, removed jet pump and tried again, no go. removed plugs and then tried spinning engine and it finally cranked but made awful screeching, metal on metal. stopped right away. pulled supercharge and found the shaft bearing was had been locked and the impeller was the sound I heard, had scrapped against the housing. New supercharger on the way. went thru upper part and could not find anything in engine, think I got very lucky that it didn't suck up any of the shavings as it never started when the scrapping was going on. fast forward to today. I'm trying to get the engine prepped for the new SC, which will be here tomorrow. When I go to start it won't go. Port engine is fine, Starboard not firing. no access to a Buds system unless I want to pay stealer just to hook up. at battery post is 12.6, at solenoid 12.6 while cranking drops to 12.4, also checked at starter and had same reading at the starter of 12.4 while cranking. also bypassed with a jumper directly to the starter and same result. Starter was just checked out by auto electrician. also checked Fuel Pressure and is at 56psi. With out plugs in the engine cranks easily and is smooth no pings of any sort or sounds that shouldn't be there. Also after cranking for a little bit, I pulled plugs and all three had gas on them, #3 though had carbon build up. all three are brand new NGK oem plugs.
Here is a video of cranking, get the 2 beeps and if I let sit get the 4 beeps on the dess before cranking. Video 1
2nd vid is cranking right engine twice followed by left engine start up and then right engine crank. Video 2
![IMG_4129.JPG IMG_4129.JPG](https://www.seadooforum.com/data/attachments/27/27617-611befb52492356790f268437c85cadd.jpg?hash=YRvvtSSSNW)
Thoughts as to what I'm missing? do I need to do what the manual says and open up to check the flywheel and trigger (which looks like a royal pain in the butt)
Thanks,
Rick
![image1.JPG image1.JPG](https://www.seadooforum.com/data/attachments/27/27615-e587e67ca787deaf42e0212fbc2ac29b.jpg?hash=5YfmfKeH3q)
![image2.JPG image2.JPG](https://www.seadooforum.com/data/attachments/27/27616-adc5b6703b8eaa8134b54b99eae4e2d6.jpg?hash=rcW2cDuOqo)
Thanks,
Rick
