SquidDaddy
First some background...
I just bought a 97 XP with the 787 that just had a new top end last season and the carbs rebuilt. An R&D Rec head was installed as part of the new top end and the compressions were at 178 and 180 when I got it. It ran really good during my lake test with the only notable problem seemed to be a bit of difficulty turning over at first but then would spin well then start. The owner said the battery was about 3 years old and could use replacing and that seemed very plausable to me.
I took it to the lake for the first time this past Saturday. It ran fine but still had the same difficulty turning over, so I naturally assumed the battery was slowly going bad. I let my wife then take it for a spin and during her dismount back at the boat, she ended up flipping it upside down. She tried to right it a couple of times without luck so I ended up diving in and getting it right side up...it probably spend 3 minutes upside down. I did roll it the correct direction. It started up again and I rode it another 10 minutes or so and came back to the boat to take a break. Probably an hour later we decided to head in but the ski would just barely turn over and finally not at all. I just figured the battery had finally gone dead....oh well I guess I will have to tow it. Being the owner of a 97 Speedster also, I knew you had to clamp the incoming water hose or tow it very slowly...well I didn't have a clamp so I towed it back at basically just over idle speed on the Speedster....less than the 10mph indicated...for probably a mile or so. When I got home I put the battery on the charger and left it over night....mind you I had no idea that I had flooded the engine with water some how. On Sunday the ski still didn't start so I figured the battery was finally gone so I picked up a new one on Monday. After charging it up all night, I tried it this morning and it was the same...no turning over and just some clicking. So I come back to forums and started searching and everything was pointing to water in the engine.
Current...
Ok so I pulled the plugs and turned it over....oh yes plenty of liquid coming out...oh crap. Well I have done the procedure in the shop manual of cranking a bit....then fogging...then cranking some....then fogging....even after a lot of cranking it always seems like more comes out. When it finally looked dry I put the plugs back in (after cleaning them) and tried to start it. It didn't start and then it wouldn't turn over any more....so I take the plugs back out and they are wet again...so I start that whole procedure over again and so on and so on. I have been doing procedure over the last three hours or so and I can't seem to get all the water out I guess. Ok so this is where I might be missing something or not doing something the correct way....at this point I have just filled the cylinders with the fogging oil and I'm letting it sit and going to wait on some suggestions for this helpful community. Thanks in advance!
-Jeff
Current...
-Jeff
