Help 95 GTX need rubber bushings!!!!
ttiot9999
was driving all day no problem then itseemed like it was runniing out of gas. SO I switched to reserve but that ran out quick. I got towed in and had water almost to the top of my battery and the purple exhaust pipe had 3 of 4 bolts gone? Were they lose? they were tight last month. Black crap is coming out and one of the plugs looked real bad I put in new plugs then fogged the cylinders the lower to bolts are gone also. It donr seem like theres water in there and the engine is still turning. I ordered a gasket and know the 4bolts will need to be replaced I have 3 of them. My question is where do I get the 2 rubber bushings for the lower part and can I use any 2 bolts and nuts for the lower part? I have a 95 GTX I also am replacing the starter but the big issue is the the 4 bolts with the gasket and the 2 rubber bushings with the bolts in the lower part. I hope if I replace this stuff it will work. I gotta get it on the water quick but need some parts and need help finding them Thanks
My boat did that last year. what a mess.
You should be able to get rubber mounts at your local dealer, or from ebay. (for used)
Be sure the screw holes are all good, the one under the corner of the exhaust is a stud with flat washer/nut, use the blue loctitie to keep this stuff in place - many auto stores have it in small tubes look for 242 in the part number. NAPA has helicoil kits if you need this to fix the holes, this does happen when someone rushes that last hour of engine install - some of the simple green spray will make it look nice again.
