fastestonehere
Just bought a 2003 GTX S.C. after 15 min. on the water loud noise from inside ski and then
it started taking on water. then rough idle warning beeper limp mode.....wow I was thinking WTF.
I found the Impeller unscrewed from shaft destroying everything in it's way. water found it's way into a connector on the lower
side of MPEM causing havic with the Ski and moisture in motor.....
well I am half way through repairs I hope. this is what I have done and also where I need help.
1 cleaned all pins on mpem and harness die electric all connectors.
2 flush engine out with oil twice and replaced filter. ******* (anything else I should do here)
3 bought a used pump assy. from a 2006 RXP with impeller ******* ( will this impeller work or should I chang this differant Pitch)
4 bought drive shaft from 2006 RXP. ****** ( what else should I need Here to work in my Ski)
I plan on upgading to 215 HP stuff wintertime I really just wanted to enjoy this unit this summer....
Big question is the impeller? a 215 hp impeller work on stock 185 hp ski
I like the feeling of launching out of 180 turns and deffenantly enjoy top speed.
This Ski is all stock. I will be upgrading in future if I need to rebuy impeller again I will.
what would you guys think a stock RXP impeller would do on this SKI
( my screen name has to do you my Drag racing stuff not Jet ski's lol)
Thanks
Thanks
