Spimothy Leary
After sticking my nose in my buddy's business I talked him into a Rossier pipe & jetworks valve with extended 95 xp tabs, splash guard. had his/my tuner install & rejet. I picked it up yesterday and took it out for final carb/tuning.
I personally have been off of 2 strokes for a couple of years now (3 from my XP) but I know what to expect, and its falling short. I took it home with me because it has needs that should be addressed.
First... started off with a noticable off idle bog and i'm chasing a RPM gremlin Hitting 7500-7600 top speed 54.4. SBT engine flame arrestors I think stock grate and prop (will confirm that) weather was low 90's humidity in the 90's as well, Gotta love Florida summers.
edit: typo... 6500-6600 rpm.
75 lows, 142.5 front, 145 rear LS out 1 1/4 and HS at 1/4 front and 1/2 rear. Popoff is low but I can't remember what he told me it was at.
We slid the HS up to 1/2 and 3/4 during tweaking it felt like it helped a little but at best pushed top rpm up maybe to 7600
what pounds should the jetworks valve be set at? I'm either at 3 or 6
note: I had not ridden this particular ski before so I had no speed/rpm or proposing baselines to work off of and after calling the owner doesn't pay super close attention he just rides.
I think we may have possibly solved the RPM issue which I'll know next time I can dunk it, after pulling it out of the water we checked and the the rave caps were fried. Almost zero thread. I put a set of OEM tops and OEM baffles on when I got home last night. (I didn't pull the blades out but perhaps I should, maybe a little gummed up too. There is still some side to side play on the rave blades, is that typical for sbt? it didn't feel right to me.
2nd issue. the porpoising was the worst, much worse than I remember ever experiencing at virtually every speed/rpm and I was on 3" chop, couldn't shake it on glass either for more than a few seconds. It din't matter if trim up/down, riding over the bars, leaning back.
I know that is scrubbing my speed as well I can't stay hooked.
assuming we have the stock grate & prop, what grates might help to resolve this?
are the 95 tab's somehow a negative contributor? Are other extended tabs different?
I thought they would help
stock nozzle, should we look at extending or aftermarket?
I always ran no grate, stock tabs and r&d extended nozzle and it was fine so I never experimented with tabs/grates.
