Mr Africa
Hi guys just want some quick info that i can't seem to find on the site.
Right finally i have my ski back after the accident, all soughted.
It has been serviced, new wearing, impellor rebuilt. Now on my first test i found that i was only getting to about 45 mph and the rpm was only 6600 rpm and the wife said it sounded like a butcher saw from a distance away and it would take a while for it to plain off.
When i got home i found that firstly the steering nozzle was facing slightly up, the plastic bush under the steering nozzle was incorrectly put in, when i changed it around the nozzle came down abit. I then found that when the steering bar was straight the nozzle faced to the left. If i stuck a straight ruler in and measured the two sides i found that there was a difference by 3mm. i have straightened that as well. Could all this make the difference in speed and not plaining quickly.
What rpm should i be getting at WOT. On trailer it hits the limiter in the water about 6680rpm. Is this normal.
Can you confirm when i do a sharp turn and then open the throttle full it takes like 2 seconds as if cavitating, is this normal.
When riding is the exhaust fully under the water or only half.
Sorry for all the questions but hey need to know so as not to make an ass of myself.
Thanks
Andrew
Thanks
Andrew
