gtx or gtxdi
leafspuck
Hey i just aquired a 2001 gtx registration says 130 hp not sure if it is a gtx or a gtxdi, it does have a reserve and i am not sure if that means it is a gtx. i need to find a replacement engine, but with a stuck motor. how do i tell the difference???
The Di version is "Direct Injection"
Look under the airbox... Do you see carbs? If it has carbs, it's not injected.
Also... is there a fuel select valve? (on, off, reserve) I don't think the Di version has a fuel valve.
Let us know what you find.
2001 gtx
Pretty sure the GTX DI says Direct Injection on the decal beneath the words GTX on rear sides of Hull, i just purchased one also and was unsure till i took cover off and mine says (Powered By Rotax Marine) not Direct Injection,of course should be easy give-away once ya got the seat off,
