Britpilot
Ski is a 2010 GTX 155. Diagnostic code is PO546 Exhaust gas temperature sensor. Ski just died and my diagnostic software pulled up this code. I erased the code and tried the ski again on the water. It started and idled ok but would not produce any thrust. Ran the diagnostics again and the PO546 code was back.
I am going to change the EGT sensor but wondered if anything else can cause this code. Is the code saying the sensor is bad or that the EGT was high? High EGT can only be caused by lack of cooling water? I am checking out all raw water cooling lines. This ski has IBR and variable trim and I notice the raw cooling water goes in and out of a fitting on the IBR actuator unit any body tell me why?
