If you’re unsure, pre mix another tank. It won’t hurt anythingI am but I’m talking about my next tank of gas.
Sounds to me like it’s running rich on the low end circuit, could try turning the low speed in 1/8 turn. Easy to put the voltmeter on the battery and run the machine to 4500 rpm to see if it is a rectifier. With it randomly losing power at high speeds, I’m not sure. I can’t remember if you rebuilt the fuel system or not? But I would go through the fuel system, if you haven’t already. Don’t keep driving it, in this condition thoughSo when I posted that other message I had the ski in the water it was running good but it would stall sometimes and would be hard starting but then other times it would start first crank. I went on an oil run because the light came on and it took about an hour. I came back and filled it up and went out but it wasn’t running right. It was like maxing out at a lower rpm as if it were cavitating but it wasn’t. Randomly it would pick up and get power and be able to go faster. If I blipped the throttle a lot it would get up in plane and I could go like I was before. It would run good till I stopped and when I went to go again I had to do the same to get up and going. When it was up and I was moving fast it seemed like it would randomly give me the real power it should have then it would drop and have less power.
That would cause it to be maxing out at a low rpm and speed?Sounds to me like it’s running rich on the low end circuit, could try turning the low speed in 1/8 turn. Easy to put the voltmeter on the battery and run the machine to 4500 rpm to see if it is a rectifier. With it randomly losing power at high speeds, I’m not sure. I can’t remember if you rebuilt the fuel system or not? But I would go through the fuel system, if you haven’t already. Don’t keep driving it, in this condition though
Correct me if I’m wrong, I read it as you were having trouble getting it up to speed but if you feathered the throttle you could eventually get it to go good? If I read that right that sounds like the low speed circuit is a little rich. You are saying that at higher speeds it would go good and then drop and have less power? To me that sounds like your not getting enough fuel at higher rpm’s. Did you rebuild the carb with a good kit and do the testing on it? Good black fuel rated fuel lines? New fuel selector valve from reputable company not Amazon? Or leak test it? Did you leak test the crankcase after rebuild? Definitely like to see what others think, but it sounds like fuel/air to meThat would cause it to be maxing out at a low rpm and speed?
Yeah if I just got on it and pulled the throttle it would go but max out at a low speed and not go any faster and more throttle wouldn’t help. The carb has been completely rebuilt with good parts and tested. The whole fuel system has also been rebuilt. I never leak tested the crankcase. It gets up after feathering the throttle but it’s iffy. Sometimes it works right away and sometimes it takes more time. When up on plane and cruising it seems like it’ll suddenly get more power without accelerating and then it goes back to how it was after a bit. It’s very random.Correct me if I’m wrong, I read it as you were having trouble getting it up to speed but if you feathered the throttle you could eventually get it to go good? If I read that right that sounds like the low speed circuit is a little rich. You are saying that at higher speeds it would go good and then drop and have less power? To me that sounds like your not getting enough fuel at higher rpm’s. Did you rebuild the carb with a good kit and do the testing on it? Good black fuel rated fuel lines? New fuel selector valve from reputable company not Amazon? Or leak test it? Did you leak test the crankcase after rebuild? Definitely like to see what others think, but it sounds like fuel/air to me
Are you saying the engine revs out fine, but you’re just not moving like you should be?Yeah if I just got on it and pulled the throttle it would go but max out at a low speed and not go any faster and more throttle wouldn’t help. The carb has been completely rebuilt with good parts and tested. The whole fuel system has also been rebuilt. I never leak tested the crankcase. It gets up after feathering the throttle but it’s iffy. Sometimes it works right away and sometimes it takes more time. When up on plane and cruising it seems like it’ll suddenly get more power without accelerating and then it goes back to how it was after a bit. It’s very random.
No it’ll stop revving up even with more throttle like it’s maxing out and if you feather it it’ll start going normal again.Are you saying the engine revs out fine, but you’re just not moving like you should be?
Check the regulator.rectifier, but sounds like a fuel issue. Where did you buy the carb kit from? Don’t think it’s your issue, but have a 1 minute ride with the seat off and look for exhaust leaks. You’re not running any aftermarket fuel filters or air filters?No it’ll stop revving up even with more throttle like it’s maxing out and if you feather it it’ll start going normal again.
Not sure where I got my carb kit but I’m certain it was an OEM Mikuni kit. How do I check the regulator and rectifier? I took the seat off while riding and didn’t notice any exhaust leaks. It has no aftermarket parts besides the impeller.Check the regulator.rectifier, but sounds like a fuel issue. Where did you buy the carb kit from? Don’t think it’s your issue, but have a 1 minute ride with the seat off and look for exhaust leaks. You’re not running any aftermarket fuel filters or air filters?
Just turn your multimeter to DCV, put the leads on the battery , check volts at rest, start the ski, see what they are at idle, I believe 12.8 ish to around 13.5 ish at idle and then see what you get at roughly 4500rpm, should be roughly 13.5 ish to 14.5 ish.Not sure where I got my carb kit but I’m certain it was an OEM Mikuni kit. How do I check the regulator and rectifier? I took the seat off while riding and didn’t notice any exhaust leaks. It has no aftermarket parts besides the impeller.
I don’t have a tachometer but I’ll do my best.Just turn your multimeter to DCV, put the leads on the battery , check volts at rest, start the ski, see what they are at idle, I believe 12.8 ish to around 13.5 ish at idle and then see what you get at roughly 4500rpm, should be roughly 13.5 ish to 14.5 ish.
It doesn’t need to be precise at all, just as long as rpm’s are increased and volts go up but stay in correct rangeI don’t have a tachometer but I’ll do my best.
Yeah I bought a new pump housing and threw my solas impeller in it and it has perfect clearance. I know the jet pump isn’t the problem because it’s perfectly capable of running good. It does seem to get up and go fine when I put the selector to the correct spot. It just keeps stalling out after 5-10 seconds at around half throttle. It’s like it runs the gas out of the lines then it’s not getting enough. I have been through the carb since the rebuild so it should be good. Everything is new in the fuel system.Not sure where your at? Did you get the wear ring changed to a good OEM one? You mentioned a cheap fuel selector valve that was giving you issues? You can bypass the selector valve and fuel filter if you think they are giving you problems. Not sure if you have rebuilt the carbs after the engine rebuild but if you haven’t, I would. If you have compression and spark? Then just go through the fuel system, back to OEM carb rebuild kits from OSD, no Amazon or eBay junk so your not chasing your tail, black automotive fuel lines, follow the carb rebuild thread, set screws to factory settings and you should be good to go.
How do you know that you don't have leaks? You could have a small leak in an O-ring and not even know it for a year. Not all clear fuel line is the same. There is Tygon, polyurethane and knock offs of both I think I have tried them all. I am no Seadoo whisper, I need help with tuning these things. On my first experience with replacing fuel line I went to an automotive parts store and bought rubber fuel line. I don't think it is Nitril...just rubber. I am still running it, but I don't know if it leaks, because I cant see if it leaks. I went to a Seadoo Tech and he said "what is that?" he acted like he had never seen traditional rubber fuel line. He used yellow Tygon fuel line. Next ski I bought yellow but I think I got the knock off brand. It got cloudy and hard, but not brittle...I can clamp it with out damage. I am still running it with no leaks. Next I bought blue from a Different Seadoo tech. It is performing about like the yellow knock off, but not cloudy. It had 1 leak. I saw it clipped the end off new zip ties...easy fix. since then I have bought 2 different blue lines one is softer than I like. but working fine. The other is new to me, but looks like the best that I have found so far. It is Lamons Corporation Polyurethane. The bottom line is that the worst clear line only takes about 10 second to diagnose an air leak before the pump. If there is no air going into the carbs, everything up to the tank is good to go.I recommend the rubber/nitrile fuel line because I’ve seen many posts stating that the polyurethane fuel line gets hard and brittle in a short time period, I’ve heard 2 weeks, I’ve heard a year, I’m sure it depends on where it’s purchased but either way your not going to get anywhere near the lifespan. You don’t have to just replace parts, you can test the selector valves and fuel filters with vacuum. The black automotive fuel line isn’t going to leak at the fittings so no need to have to look for air bubbles
