I have a 07 GTIse 130 four stroke, it started Friday, Saturday it would just click when you hit the start button. Check battery, cleaned and tightened cables and checked fuses. Any thoughts, sound came from front of machine. Thanks
Jump the starter solenoid, if it cranks then the battery, cables, connections and starter are good. If not, one of those are bad. Did you have the battery load tested?
Yes load tested battery. Is the starter solenoid below the fuse box with the 2 red leads coming into it? Do I jump it with a wire and hit the start button? Thanks
Will be two large leads. One from the battery and the other goes to the starter. The moment you jump it, it will give power to the starter. Use a heavy screwdriver or pliers as it will be a heavy load. A small wire will melt or burn you.
