Grey line change out, Need to change vent hoses too?
77Eltigre
Basically title, I have a 94, thats entirely original, ran good at the end of last summer, but I have the time so I'm going to change the hoses out and hope I get away from having to do a carb rebuild.
My question is: is there any benefit to changing out the grey hoses that are the vent lines?
Also the pressure relief valve on the port side (left side) is that just a friction fit? or is there a method to remove it and install a new one?
Thanks
They are probably good, I would do an internal inspection, as much as you can, on them. Look for deterioration. They have been on there a while and and I don't think they are rated for 20plus years of service. If they look good you can keep them. Don't forget to check your vent valves for good operation.
But..... I personally would change them out. Its easy while you are in there and have all that new hose laying around.
I would replace them because the vapors do the same thing as the gas and it ends up clogging the check valves. I had this problem and didn't even realize it. It's not much more line depending on your machine. Also for the check valve/pressure release, you need to just pull it out maybe wiggle in a little, or push it from the outside if it's not budging
I found that the dreaded green goo forms wherever the grey hose comes in contact with fuel and brass fittings. The carbs and fuel selector were problems for me. I didn't see a reason to change the vent lines so i didn't.
IMO...As long as you take them apart and inspect them for wear, etc... you should be alright. But remember hoses have a life span, most hoses are way past due on our skis, good maintenance goes a long way. Good luck
I have never seen the Tempo lines go bad on the vent side and I don't change them.
