Picked up a 2000 Kawasaki Ultra 150 on single Shorelander trailer and a 1995 Seadoo XP on a double galvanized trailer for $400. Did a quick clean to removed 5 years worth of sitting under trees in someone's backyard. Both skis came with owners registration and titles on the trailers. I had to bring 4 tires and swap out all the way around on both trailers to be road ready. After I got home I looked in the drybox and there were two new tires in it. Both turn over and have spark. Sprayed cylinders down with fogging oil. Gauges surprisingly still work. Will pick up a couple of batteries and start the process of rebuilding carbs etc. The seadoo has the gray lines already replaced and is pre-mix. The Ultra has a primer.
