my screw counter sinks about half way in before getting tight
I replaced the o ring and put rtv on still got a little water
Just until you feel pressure. The locktite will keep it from backing out.
Lou
Sorry we got a little sidetracked and I've been at the lake, anyway back to your original question. The other place where a leak is possible it the double lip seal on the impeller shaft at the impeller end of the pump. Part no. 3.
http://fiche.seadoowarehouse.com/se...odelid=1997 Sea Doo PWC GTX PROPULSION SYSTEM
Lou
Do you tighten the screw until it bottoms and is tight or just until it's a little under the cone surface?
The plug on the pump cone is a tapered 1/8-27 pipe plug, it shouldn't go thru. As another member posted, Pumps should pressure tested to ensure the shaft seals & o-ring are sealing properly.
you would have to pull the impellar to replace this part correct?
The plug on the pump cone is a tapered 1/8-27 pipe plug, it shouldn't go thru..
Mine bottomed but I'm not sure it is bottoming on the shaft or there is thread bottoms on the cone???
Just a heads up Lou, 30 PSI is way too much. Spec calls for Max 10 PSI for 10 min.Yes, have you pressure tested the pump? Apply about 30psf air, and spray soapy water around the cone, look for bubbles, the cone "O" ring seal is the most likely place. I've only had a problem with the double lip seal leaking one time.
Lou
So then it is fine to tighten the plug until it is tight?
If I tighten it until it's tight, I will not be hitting the shaft?
I really don't want to have to tear 2 of these back apart.
Thanks
If your cone is plastic the threads can be stretched easily ruining the cone.
