DnKSeadoo
I am working on diagnosing a surging problem I am having on my 96 sportster. I have cleaned the fuel filter, blew out the fuel shut off valve, took out the fuel tank baffle and cleaned the screen. There was not a lot of debris obvious in any of these areas. However I did find one of the fuel return tees that appeared to be cracked. Then when I touched the tee it completely broke. I am replacing that and putting it all back together. I also checked the carb linkage and all was working properly. I didn't go into the carb since I didn't find any debris anywhere else in the system.
So I'm wondering what the next step is. I'm confused on the vent on the side of the hull. Is this supposed to be a check valve or just a vent. I can blow into the valve and suck air out of it. Can this be sucking air into my tank and causing my surging problem? The surging happens over half throttle.
I'm new to this boat, just bought it last month and had it out twice. The first time out it was fine (on a full tank of gas), then the second time on about a 1/2 tank started surging over half throttle. When it was in smooth water I eased into the throttle and had my buddy go into the front of the boat to try to keep it level. As soon as the front came out of the water it started to break up. With the extra weight we were able to get it on plane and it was fine. But the second we came into choppy water and unlevel it started to surge again.
Please clarify if the vent on the side of the boat is supposed to let air in and out or just out. Any help is greatly appreciated. We are desperate to get it out on the water!
